Max Recommended Distance That Thermocouple Wire Can Be Run
I trying to determine the maximum length that thermocouple (extension) wire can be run from the connection head directly to a PLC T/C board. Is there a standard (API, ISA, IEEE, etc.) which addresses this installation question?
Best,
KC
Best,
KC
RE: Max Recommended Distance That Thermocouple Wire Can Be Run
it is a engineering not a standards item although some customers may have recommended practices that you have to comply with.
