FACE COLORS- GET RID OF THEM/HAVE PART THE SAME COLOR
I have a part that was imported with each face seperatly colored. Each face is colored gray, and I want to change the color of the whole part. I open the part file, click on the name of it, then click on the color button, and part in the drop down selction is grayed out-unselectable. Then when I select a face of the part, and hit color, the face is changeable. I've tried to put the face filter on and windowed the part, which takes a while to select all faces that are visible to the particular view I'm looking at, and remove the color. That works, but the faces that are not visible from that view dont get color removal. I've done the same thing by using each standard view angle,and get most of the faces, but not all still.
Their's got to be an easier way-please send help.
RE: FACE COLORS- GET RID OF THEM/HAVE PART THE SAME COLOR
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
The project is posted at <http://www.esoxrepublic.com/models>
filename: "MakeAddinFromExeVB.zip"
In the zip file is an .exe named "ScrubFaces.exe". There is also an addin version named "ScrubFaces.dll"
http://www.EsoxRepublic.com
I have played with the photoworks a lot on this file, which may have something to do with it.
Photoworks might have cuase you some problems, but I can't
think how or why it would.
Scott Baugh, CSWP
That setting is not checked... I tried to mess with those settings, to no avail.
Scott...
I sent you a copy of the part at your scottjbaugh site...
Maybe you'll see what is wrong? I need to fix this before I submit it to our customer.
Thanks everyone.
