Design table for assemblies?
Good morning, everyone.
I'm attempting to create a sheet metal layout for valve insulation blankets, and was wondering if I can use a design table for the following.  If not, any ideas would be helpful.
The assembly would be composed of 3 parts : the valve itself (not in its entirety, but only two "teed" cylinders showing the flange diameters), the main valve wrap, and a bonnet wrap.
The main valve wrap and the bonnet wrap would cover the valve model, with appropriate slits for unfolding, and cutouts for the intersection of the two pieces.
I'd like all of the above sheet metal parts to relate to one another each time I input the dimensions for a valve and adjust accordingly.
Does it make sense, and can it be done?
Brian L.
RE: Design table for assemblies?
No it doesn't make a lot of sense to me, but it's still very early.
From what I gather the one thing you have to do is incontext your files.
Look up incontext in your SW help.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
I've done one from scratch, without any linkage between the dimensions.  Care to take a look?
Sure, that will always explain more than trying to explain the problem.
Post a link or try sending it to my email via my website.
Scott Baugh, CSWP
