Query Problem with Access 97 Database via ASP
Hello All!  I am having a query problem on a numeric value.  I am using the Access 97 database.  It comes up with the following error messages:
Microsoft JET Database Engine error '80040e07'
Data type mismatch in criteria expression.
/ds3select.asp, line 57
Please help!  Thanks a million!
Below is the short script that I used:
' Declare our variables... always good practice!
Dim strURL     ' The URL of this page so the form will work
               ' no matter what this file is named.
Dim cnnSearch  ' ADO connection
Dim rstSearch  ' ADO recordset
Dim strDBPath  ' path to our Access database (*.mdb) file
Dim strSQL     ' The SQL Query we build on the fly
Dim strSearch  ' The text being looked for
' Retreive the URL of this page from Server Variables
strURL = Request.ServerVariables("URL")
' Retreive the term being searched for.  I'm doing it on
' the QS since that allows people to bookmark results.
' You could just as easily have used the form collection.
strSearch = Request.QueryString("search")
' Since I'm doing this all in one page I need to see if anyone
' has searched for something.  If they have we hit the DB.
' O/W I just show the search form and quit.
<p>Search our DS3 database by ECP number.  (% returns all)</p>
<form action="<%= strURL %>" method="get">
<input name="search" value="<%= strSearch %>" />
<input type="submit" />
</form>
<p>[Try '176' for an example]</p>
If strSearch <> "" Then
    ' MapPath of virtual database file path to a physical path.
    ' If you want you could hard code a physical path here.
    strDBPath = Server.MapPath("/ds3/ds3.mdb")
    ' Create an ADO Connection to connect to the sample database.
    ' We're using OLE DB but you could just as easily use ODBC or a DSN.
    Set cnnSearch = Server.CreateObject("ADODB.Connection")
    ' This line is for the Access sample database:
    cnnSearch.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & strDBPath & ";"
    ' We're actually using SQL Server so we use this line instead:
    ' cnnSearch.Open Application("SQLConnString")
    ' Build our query based on the input.
    strSQL = "SELECT ecp, carrier, t1id " _
        & "FROM b1cell_alpha " _
        & "WHERE ecp = '%" & Replace(strSearch, "'", "''") & "%' " _
        & "ORDER BY ecp;"
    ' Execute our query using the connection object.  It automatically
    ' creates and returns a recordset which we store in our variable.
    Set rstSearch = cnnSearch.Execute(strSQL)
    ' Display a table of the data in the recordset.  We loop through the
    ' recordset displaying the fields from the table and using MoveNext
    ' to increment to the next record.  We stop when we reach EOF.
    ' For fun I'm combining some fields and showwing you can do more then
    ' just spit out the data in the form it is in in the table.
    <table border="1">
        <tr>
        <th>ECP</th>
        <th>T1 Circuit ID</th>
        </tr>
    Do While Not rstSearch.EOF
        <tr>
        <td align=center><%= rstSearch.Fields("ecp").Value %></td>
        <td align=center><%= rstSearch.Fields("t1id").Value %></td>
        </tr>
        rstSearch.MoveNext
    Loop
    </table>
    ' Close our recordset and connection and dispose of the objects
    rstSearch.Close
    Set rstSearch = Nothing
    cnnSearch.Close
    Set cnnSearch = Nothing
End If
' That's all folks!  See it's really not all that hard.
