Matlab compiler: C/C++ code portability
I wanted to know if the C/C++ code obtained using matlab compiler in Windows can be ported to Linux. Will I need matlab for linux to compile this code there or I can compile it with any ordinary C/C++ compiler ?
Thanks for help.
RE: Matlab compiler: C/C++ code portability
You will need MATLAB on Linux to compile on Linux anything that needs a library or any proprietary functions like the math library.
