Online calibration
Online calibration
Hi All,
We have a 78 % H2SO4 storage tank whose Level transmitter is not working. (DP type). we are not able to isolate the valve so that we can calibrate the LT.We have sufficient quantity of acid inside which we dont want to drain. Is there any way to solve this problem or calibrate the LT?
thanx
all2win
thanx
all2win
RE: Online calibration
you may be able to add a second level or pressure sensor and juct replace the output.
How much accuracy do you need? can you access the tank
and the acid without draining?
<nbucska@pcperipherals DOT com> subj: eng-tips
it's not smart type transmitter.I dont want much accuracy and moreover i cant isolate the LT without draining.
i think i should go for the Age-Old Dip stick method.
thnx
capacitive sensor, too. If you could send me the measurements of the tank and quantify "not much accuracy"
I could help more...
sticking the tank never fails and comes calibrated from the factory! Certification results are extra of course.
