design table in assembly
How do we make design tables so that the change in configuration in a part changes in the assembly. Thank you.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: design table in assembly
Your going to have to explain your situtation in furhter detail.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
If you want the assembly to be shown with different configs of a part you need to create different configs of the assy.
But to get change in configuration in a part change in an assembly - that I am not sure of.
How about and example, that may make your problem simple for us.
In the appropriate row of your configurations, you would then call out the desired configuration name of the part.
Christopher Zona
Litens Automotive Partnership
Concord, Ontario, Canada
