Group command is behaving differently, why?
I am using AutoCad LT 2002. I have been using this version for 2 years now without problems.
I have the habit of selecting several objects then right clicking to get the shortcut menu which I use to Group these objects quickly.
I have come to expect that after I group these objects that all of them will be selected when I select only one of the group.
Recently (yesterday) I found that when I select one member of a group none of the other members are selected.
Is there a control command that will restore the group function to the way I am used to using it?
RE: Group command is behaving differently, why?
try "GR" @ the command line
this will bring up the "Options" dialog box
make sure "Oject grouping" is checked, then [OK]
this will select all, when one of a group is selected.
hope this helps.
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Thanks, I was sure it would be a simple solution but I couldn't find it.
