G D & T Settings in ACAD 2002
I have a file that is set for ANSI Y14.5M-1982 and I want to convert it to the current spec.  I can not find the setting to allow me to change.  I would appreciate any help.
RE: G D & T Settings in ACAD 2002
If you are using AutoCAD Mechanical, then select ASSIST >> Mechanical Options >> Standards TAB >> Then expand the Feature Control Frame tree, and select ANSI Y14.5M-1994
"Everybody is ignorant, only on different subjects." — Will Rogers
Borg,
I'm using regular AutoCAD 2002.  It seems to have a default of ANSI Y14.5M 1982.
