Erosion Corrosion of CS Pipe in Limestone Slurry
Does anyone know, or have reference to, the erosion corrosion rate of a straight section of CS A106 GrB pipe under a limestone slurry service? The velocity of the slurry is 8 fps with a 44 micron limestone particle size. I am trying to justify, or prohibit, the use of straight sections of CS pipe for this application. The driving force for using the unprotected steel pipe is cost savings. Of course for bends and certain straight sections (15D-20D) after bends, a basalt lined pipe will be used.
Test data would be most helpful.
Thank you.
Thank you.
RE: Erosion Corrosion of CS Pipe in Limestone Slurry
Call me if you want convincing DW
Venton, P. B. 1982. The Gladstone Pipeline. Working paper A-4, BHRA Group, Hydrotransport 8.
