How to remove Loctite620
3
  Would like to know, other than heating, is there any chemical that can remove Loctite 620?
Regards.
RE: How to remove Loctite620
Locktite did make a remover.
Several other people also marketed a debonder. Look in Grainger's or McMaster-Carr's catalogue.  Another good place to check is some of the larger bearing houses.
Many gun cleaners like for example Hoppes#9 will soften most Loctite compounds.
