API - Applying Sketch Relations "Batch-wise"
I have frequent need in sketches to add a large number of relations which are points (end points of lines) coincident to a single line.
For example, imagine a zig-zag or sawtooth and then a single line to which you want each vertex to be coincident.
Is that something that could be programmed so that I could select one line and a bunch of vertices and then have the coincident relations added one-by-one? It seems tailor-made for a For...Next loop.
Bring back the HP-15
www.hp15c.org
