1% Proof Strength of Stainless Steel
Section 6.7.4.3.3 of the IMDG and ADR codes for the design of portable tanks calls for the use of the 1% proof strength for austenitic steels.  Section 178.274(c)(2)(ii) of 49CFR also cites the use of 1% proof strength.
What is the source of this data for SA240 Grade 304 Stainless steel?  Does it differ from the specified Yield Strength from ASME Section II, Part A?
RE: 1% Proof Strength of Stainless Steel
Yes it differs, the standard yield strength is taken at 0.2% strain.  You need to have it measured.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
