Set Rotate Point Shortcut Key(s)
Hi All
Is there a shortcut key in UGNX-2 for setting the rotate point?(Similar to F3 select object in CATIA V4)
Or is it possible to set up custom shortcuts?
TIA
TIA
RE: Set Rotate Point Shortcut Key(s)
information-->Custom Menu Bars--> Accelerators
You can CHANGE your Accelerators by editing
\ugbasedir\ugii\menus\ug_view_popup.men, search for
BUTTON UG_VIEW_POPUP_SET_ROTATE_POINT
LABEL &Set Rotate Point
ACTIONS STANDARD
and change it to something like:
ACCELERATOR Fx <-- whatever accellerator you want to use
ACTIONS STANDARD
It is very important that you assign a previously unassigned value to this. You can unassign another action by editing either the same file or editing ug_main.men, and commenting the ACCELERATOR line out, or changing the value.
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
