Hole wizard fit call outs.
I there any way to create a favorite drilled hole that will give me say an H7 tolerance with the drilled hole for a dowel pin.  I have tried editing the 3d sketch dimension and adding the H7 or what ever and it works, I tried going in and editing the feature in the hole wizard, but it does not pick up the fit for future holes.
RE: Hole wizard fit call outs.
Sounds like you need to add a custom Database to use for any speical holes you want to make - See this link on how make a new Database - http://www.scottjbaugh.com/Tips_Tricks/Data_Options.htm - Remember though if you make new (customized) threaded holes you will need to add them to the Thread Data at the end of your new Database.
Scott Baugh, CSWP
http://www.3dvisiontech.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
