ID honing done with machine centre
Hi there,
Can anyone recommend me a supplier who's selling the attachment/assembly unit that can fit into a conventional machining centre in order for it to perform ID honing process.
Best regards,
ct
RE: ID honing done with machine centre
Typically machining centers do not perform honing because abrasives and ways are a problem.
I have honed on a lathe using a diamond hone. I found the following link and maybe your answer.
http://www.accucutdiamond.com/superabrasives.htm
You can get any finish you desire.
http://www.engis.com/borefinishing/tools.html
This website is a part of Engis. The Helical Lap is for troublesome bores. Like bores with holes of keyways and such
http://www.helicallap.com/
