ET100 EPROM dead!!
ET100 EPROM dead!!
ET100 EPROM dead!!
I am in a spot of trouble. I am working on a machine using a 115U PLC within which is an IM308 card but the EPROM within this card has lost its contents I need to write a replacement has anyone got any ideas on calculating the address of the IO on the system?
The system uses two ET100 racks, at address 1 and 2
In rack 1 there is an analogue input card, a high-speed counter, and two digital input cards.
In rack 2 there is two analogue input cards four digital input cards and four digital output cards.
The major problem for me is calculating the start address for the four types of IO, digital in, digital out, analogue in, and analogue out, as this must be the same as the original EPROM in order to mach the code in the CPU.
I see the following immediate questions:-
1) Is a high-speed counter card a digital input card?
2) As the master rack is a 115 rack does this mean that the IO area must be P type? And what implications does that give in terms of addresses?
3) As there are Digital inputs on the main rack and the two ET100 racks does this mean the address of the digital inputs must run contiguously across all racks or is it possible to have the same address for digital cards on different racks?
If you can help with the above questions and also if you know of any other tips for calculating these addresses I would very much like to know.
Many thanks
Nick.
RE: ET100 EPROM dead!!
Contact the MFR.  Even if you knew what you are doing,
it may still take several months of work -- so it is hopeless.
<nbucska@pcperipherals DOT com> subj: eng-tips
nbucska,
Actually I only need to calculate 8 bytes of data and there are lots of limitations as to what those data bits can be. I manually unpicked about 500 pages of code and on the first scan have narrowed the options quite considerably.
However, thankfully, the MRF came though with the goods and I am saved from this one.  Quite nice to confirm I was on the right track though.
