Cooler tube material
Does any one know what the difference between CuNi30Fe and CuNi30FeMn?. What exactly improve.
This is the tube of sea water cooler for interstage cooling.
sgms
sgms
RE: Cooler tube material
Manganese added to the Cu-Ni alloys acts as a de-oxidant and de-sulfurizer. Also, manganese increases the working characteristics of the Cu-Ni alloy, and further increases corrosion resistance in marine applications.
The susceptibility to flow related erosion and sulfide corrosion are reasons why high performance stainless steels are often used in sewater cooler applications in place of Cu-Ni alloys.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
