Concrete driveway in Northeast
Part of a home project involves redoing my driveway...contractor wants to do a concrete driveway but I rarely see anything but blacktop in my town (Upstate New York).  I am concerned about effects of salt and freezing/thawing and general appropriateness of a concrete driveway in my neck of the woods. Ideas?
RE: Concrete driveway in Northeast
For salt/freezing/thawing/spalling be sure to use air entrainment in the mix (probably 6% - 7%).  In the upper midwest (where winter is also severe) there are numerous concrete driveways everywhere.
Also lots of concrete driveways in Anchorage, Alaska but most are asphalt, probably more due to costs and ability to withstand ground movement due to freeze/thaw of subgrade soils. Like JAE said, air entrainment important otherwise mix is pretty typical. May be difficult to construct on steeper slopes (over 4% to 6% I'd guess).  Also starting to see more concrete driveways with embedded pipes for snowmelting.  This can be done with asphalt driveways also.
A good high strength mix 30-35 MPa min., 3" slump (very stiff and hard to work but do-able) and for a local contractor, you might push it to 4".  Air 5-7% for 3/4" aggregate, 2" cover to any rebar and preferably epoxy coated bars, sawcut at the right time (about 8 hours after finishing, as soon as the concrete is hard enough to sawcut), and a couple of coats of silane/siloxane sealer should give you an A1 pad...
Forgot to add the panel size.  Sawcut into approximately 15'x15' squares for a 6" slab. and make sure that the granular base is well and properly compacted.
