Anodize over Flame spray
Have a part that required flame spray Mil-Std-869,Then hard anodize Mil-a-8625 type III. First attempt flame spray pitted and peeled after anodize. Flame sprayer says you cant anodize over flame spray.Does anyone know about these processes?
RE: Anodize over Flame spray
I have never seen the requirement for Hard Anodize on Aluminum Flame Spray. Doesn't mean there isn't one, but it doesn't make sense. Aluminum Flame Spray is a very soft Aluminum Base Material (1100). If a harder material is required (for a Hard Anodized Surface), a harder Plasma Spray Material should be called for.
Aluminum Flame Spray is used for electrical protection or as an Antenna, not a wear surface.
I wouldn't "grind" Aluminum either!
Don't know what SF Aluminum is, but will check it out.
Just curious...what is being repaired with Aluminum Flame Spray?
Anyway, whether the plame spray coating is for dimensional restoration or a wear resistant coating like carbides, anodizing over a flame sprayed coating seems VERY strange to me, as this process needs really 'contact' with the base material.
