Oil heat capacity
Oil heat capacity
Does anyone know the name/author of this correlation for heat capacity of an oil?
cp = (1.63 + 0.0034*T) * SG ^ (-0.5)
cp in J/kg.ºC
T in ºC
SG - Specific gravity
Where is it referenced?
Thank you.
AndreChE
cp in J/kg.ºC
T in ºC
Thank you.
AndreChE
RE: Oil heat capacity
A clarification: specific gravity in this case refers to the ratio of the mass of a given volume of oil to the mass of an equal volume of water, both taken at 60oF.
The above formula appears in Engineering Tribology by Stachowiak and Batchelor, as Vol. 24 of Elsevier's Tribology Series. The formula is said to give a rough estimation of Cp values. They quote it from A. Cameron, Basic Lubrication Theory, Ellis Horwood Limited, 1981.
In which issue of Elsevier Vol.24 is this correlation stated?
Thank you
AndreChE
ISBN 0 444 89235 4
formula 2.21 .
Good luck.
