Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
kadego (Automotive)
24 Aug 04 10:00
Hi all.
How does one join faces to create a sheet body?
How does one join sheet bodies to create solid bodies?
TIA
Helpful Member!  cowski (Mechanical)
24 Aug 04 10:38
To join sheet bodies use the sew command. If the sheet bodies enclose a volume, a solid is created. If a solid body is your goal you may find it easier to create the solid first and trim it away with your sheet bodies (kind of like sculpting, start with a large block and then create trim tools to get your final shape).
Helpful Member!  Xwheelguy (Automotive)
24 Aug 04 10:44
A couple of important things to note for beginners.  Under Preferences -> Modeling there is a setting to toggle between Solids & Sheets.  If this setting is toggled to Sheet & you try to sew, the enclosed volume will not fill in to create a solid, but rather remain a "shell" body of sewn sheets.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
schoryan (Automotive)
27 Aug 04 16:39
say you have 4 lines/curves connected you can use thu mesh curve or thru curves to make a sheet
when you have multiple sheets and want to join them together
go to insert/feature operation/sew
thru mesh curve and thru curve is found in
insert/free form feature
designer gooroo
catia v5
unigraphics nx
pro-e wildfire
ideas v10
autocad 2004
27 Aug 04 18:02
schoryan,
I'm not picking on you (honestly I'm not) but you don't have to have connecting curves to create any Through Curves or Through Curve Mesh features.  The curves only have to be within the Distance Tolerance & not connected.
I say this because it's important for users to understand how the Distance Tolerance works & when it's used.
I may be wrong, but I think he was only asking how to sew surfaces into larger sheets & eventually solid bodies, not how to create surfaces.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
30 Aug 04 9:34
so your telling me you build sheets with using thru mesh curve and using curves that arnt connected? seems a bit inaccurate.
designer gooroo
catia v4 & v5
unigraphics nx2
pro-e wildfire
ideas v10
autocad 2004
30 Aug 04 11:38
Yes you can....that's what the distance tolerance is for....to approximate a sheet through the curves.  And WHERE did I say that I personally did that?  Re-read my post.
UG's tolerance is there so that IF it needs to use it to create a body, face or edge, it will use it.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
