Mack, Scania & Volvo engines data needed
hi guys,
I`ve been looking for following data: bore, stroke, conrod length, piston pin offset, no. of main bearings, valvetrain type, no. of camshaft bearings, compression ratio, cylinder firing order, valve timing, valve lift, port diameters, fuelling (mm3/inj), used turbo type (drawing/sketch/image of manifold would also be useful) for following engines: Mack ENDT975 (maxidyne), scania DT12-470HPI turbocompound and volvo turbocompound.
also a tip where it could be found is appreciable
many thanks
regards
