How do we make Tapered NPT threads in CatiaV5
Is there a quick way to make an NPT threaded hole in V5?
RE: How do we make Tapered NPT threads in CatiaV5
As far as I know, you'll have to add a standard by entering a .txt file with the different dimensions in it.
As an example (helicoil screw-thread)
ThreadDiam. Pitch    HoleDiam.    M
3.08mm        0.45mm    2.60mm            m2.5
3.65mm        0.50mm    3.10mm            m3
4.91mm        0.70mm    4.10mm            m4
6.04mm        0.80mm    5.20mm       m5
7.30mm        1.00mm    6.20mm            m6
Standard can be added under the hole-function
