Some unregenerated dimensions in drawing
hi friends,
When i create drawings and create some dimensions using Create>dimensions, Some of them are "ad#" type and some of them are "add#".
Now If i Try to make some dimesional modification in parts some dimesions will not regenrate in drawing mode.
Why?
Nikhil Gothankar
Why?
Nikhil Gothankar
RE: Some unregenerated dimensions in drawing
If this is the case,I guess you should try regenerate >model & draft both in drawing mode.May be it helpfull. Try it & pl. do let me know too.
Created dimensions can't be modified in drawing mode.
They are deletable not eraseable.
thanks!!!!!!!!
dinesh
If you create a Dimension in the drawing only with no relation to the part, it will not be regenerated.
Amish Bhushan Goel
Engineer
Hitech e Soft
amg@hitechesoft.com
