Analyse - BILL OF MATERIAL
When using that functionnality,
how do you make BOM format Definition persistent from one session to the next.
Sap
RE: Analyse - BILL OF MATERIAL
there are two possibilities,
1) modify configuration files:
You can modify the structure of the bill of material window in the CATAsmBom.CATNls file and the size of the columns in the CATAsmBom.CATRsc file.
On NT, both files are under your CATIA installation directory :
...\intel_a\resources\msgcatalog\CATAsmBom.CATNls
2) use macro
-create BOM-format You want
-start recording macro
-go back to BOM and save it
-stop recording
-edit macro, remove save command
-run macro when You want to restore settings
(macro don't save colunm width)
regards TPale
Right on!
thanks tpale
Sap
