How can I save color info when I save a drawing to dwg?
I am trying to save a drawing which contains diferent models of diferent colors but when I export this file to DWG all the models show a unique color. I have tried with the "dxf_export.pro" map file but I can only change one color for all models. Is it possible to save color info when you save from Proe to Autocad?
Thank you!
RE: How can I save color info when I save a drawing to dwg?
Do you have the drawing "showing model" by model colors before exporting.
We can set the drawing to show default or by model colors now; I wonder if that will export out differently.
