pop up menu keeps changing
I use the middle button for a popup menu. Lately, the menu has been changing for no apparent reason. I have to close out AutoCAD and then restart to reset the menu. Any ideas? I am running 04.
Thanks in advance.
RE: pop up menu keeps changing
How is it changing? Does it change items or just not work?
"Everybody is ignorant, only on different subjects." — Will Rogers
it changes all of the items in the popup menu. I have it customized for all of the OSnaps and various other commands. However, periodically, it just changes. I haven't been able to replicate what causes it...the menu reverts to basically just cut/paste/copy...etc
Very odd!!
Hello mfpd,
Try this - use the PURGE command to delete previous versions of your drawing.  I think ACAD is loading previous versions of your drawing, instead of loading current version.  I had a very about the same problem about three months ago and had to use this command to correct this situation. Hope this helps - John
