AISC seismic bracing design routine
Is anyone aware of a routine that will do bracing gusset plate design for connection design (plate thickness, bolts, welds, etc). Ideally it would be Mathcad (that I can modify if I want). Alternatively, it could be a procedure that could be put into Mathcad. Not so ideal, it could be part of an engineering software program.
RE: AISC seismic bracing design routine
www.engineering-international.com
