Packaging Calculation!
I would like to write the program for packaging calculation. To find the maximum number of single-size box into outer box.
Could you please advise the basic concept for this calculation?
Many thanks in advance for all advice!
Kae
RE: Packaging Calculation!
Sounds like a typical homework problem for a programming class... do you have an algorithm in mind?
if each piece can be assumed to be a parallelepipedon:
Try each possible orientations.
Else try to fit 2 units into a common PE.
<nbucska@pcperipherals DOT com> subj: eng-tips
