Connecting offset shells
I am using shell63 to model a fiberglass circuit board with an adhesive layer around the top, and and aluminum heatsink on top of the adhesive, all which have some thinckness. I need to link the adhesive to the top of the board, and the heat sink to the top of the adhesive, but since shells model as 2d I cannot simply merge the nodes, and I do not want to increase the tolerence to the thickness of the components so this would work. Is there an easy and efficient way to link the layers, or am I going to have to connect each node individually?
Thanks for the help
~Scott
Thanks for the help
~Scott
RE: Connecting offset shells
Hope this helps
