Titanium
Titanium
Titanium
Can anyone please give me examples of components and systems that NASA uses titanium alloys for?
RE: Titanium
One example: Satellite Cryogenic coolers (Stirling Engines)
RE: Titanium
Turbine engine inlet stators
Best Regards,
Heckler
Do you trust your intuition or go with the flow?
RE: Titanium
Ti is overrated as a general structural material, unless you need high specific strengths, in which case CFRP is a competitor, or high temperature performance, in which case ceramics might be an alternative. So have a look at apps where either of those are relevant.
Cheers
Greg Locock
RE: Titanium
The SR-71. Titaniumn accounted for 93% of it's structural weight. At the speeds it flew, the sustained high heat soaking of the SR-71 took airframe temperatures to 570 degrees C. At that temperature, aluminum would practically melt, or at best, have the strenght and consistency of soft licorice.
Aluminum is light and cheap, but loses it's strength with elevated temperatures. Steel and titanium can withstand heat a lot better before elevating temperatures cause loss of strength. Aged B-120 titanium weights only half as much as stainless steel per cubic inch, but has a similar tensile strength.
But titanium is more expensive, and more difficult to fabricate. It also has a few weird flaws that require special handling. Titanium is not compatable with chlorine, florine, or cadmium.
