Create different scene
What is the best way to do a different scene? I use Mdt 4.0.
I have bound external parts into an assembly and constrained them. I want to make different scene.
Must I move each component separately or Mdt 4.0 recognizes combined assembly and it is enough to move only one component to change his position? What should I do that it would be enough to move only one component to change entire
assembly position? Thanks; Alec 25
RE: Create different scene
Assuming the model is completely assembled and constrained;
U can ask for a new scene and have different explosion factors. U can control the invisiblity of each part from scene to scene by right click on part in browser.
May times I will "tweak" a part to create the scene I want.
Use Transform option of tweak instead of move.
