Edit Detail View
Edit Detail View
Is one able to make an existing detail view larger,
ie. increase the size of the boundary circle to
incorporate more information?
RE: Edit Detail View
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I usually manually create the detail callout in the parent view then expand the detail, add the appropriate circular view boundary that I want & then edit view boundary & use the view dependent circle as the detail's view boundary. It's a little more work, but I can then control the size of the both the detail view boundary AND the detail callout.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
I've since found in the help files something.
Headed: Editing a Circular Detail View Boundary
1. Choose Drawing, Define View Boundary.
2. Select the circular detail view.
3. Select the detail view boundary (or the detail circle on the parent view) and drag it to the desired size.
4. Press MB1 to define the new detail size.
I managed to get to step 2 but step 3, no can do!
Are you familiar with this way and if so what am I doing
wrong because the instructions seem so easy but just don't
work for me!?
'It's tough in Africa'!
