Deck Ledger/Point Load
I have a 2nd story deck hung by 3 beams on metal hangers ( 10'apart) attached to a 2"x10"x20'ledger bolted (2-1/2" bolts & nuts @16"o.c.)through dbl. 2"x10" blocking between each joist. At 50lb.psf the outer beams (2-2"x10") at the hanger ledger connection would have a max. load of 1500lb. and the center beam (4-2"x10") 3000 lb. Is this ledger strong enough for these point loads.
All comments appreciated.
RE: Deck Ledger/Point Load
The blocking rests on sill plate of foundation (walkout basement). Blocking is nailed with 3-16d nails through each side of the floor joists into the ends of each side of the blocks.
What remedial action can I take to add to the shear connection if needed?
