Change Templates in Inventor 9 Drawing File
 I am working on a drawing file and would like to change templates without starting a new drawing from scratch. I have looked through all of the online help and can't seem to find any info on this. Any help would be appreciated.
Paul R. Persiani
Tustin, CA
RE: Change Templates in Inventor 9 Drawing File
From the browser in Inventor of the drawing with the template that you want, right click on the border or title block that you want and select copy. Then go to the other drawing and paste it into the other drawing. You will need to delete the template already in the drawing before you can place the new one. If you are using the custom tab in iproperties to define the fields in the template they will all update automatically.
-Brian
