Checking H2S corrosion pipe
Hi Fellows,
How can I be sure that H2S is the source of corrosion os upper side of a gas pipeline, we assume 5 ppm contents in our gas production.
RE: Checking H2S corrosion pipe
Thank you very much. But you coud be a little bit more specific concernig to RXD.
