Wrong chilled water pipings installation
In case a chiller is installed in such a way that the chilled water inlet and outlet pipes wrongly, for example, CHW(7 degC) pipe connect to chiller's water inlet nozzle and CHW(12 degC) pipe connect to chiller's water outlet nozzle.
What will happen if they run this chiller in this condition? Will there be a tremendous drop in performance/capacity? Or something else?
RE: Wrong chilled water pipings installation
I presume you are changing the evaporator configuration from counter flow to parallel flow.
