Optical Solar Power Satellite Relay
Hello, I've posted my most recent paper on optical solar energy transmission to Earth on my website. This is one of my foundation space infrastructures, eventually leading to greater things. If anyone would care to nitpick it and point out any obvious laws of nature that are violated, or impracticalities that preclude it?
http://www.geocities.com/womplex_oo1/AeroSpace.html
RE: Optical Solar Power Satellite Relay
TTFN
TTFN
TTFN
Try to asses saving and expenses to see what the total project economy will be and try to establish a plausible project schedule. Without a sound economy no project will fly
Best regards
Morten
"The example design consisted of a 600-meter diameter Fresnel lens made of type-214 quartz in a close polar orbit around the Sun, a 600-meter diameter relay lens located at the L1 Lagrange point, a 600-meter diameter reflector lens orbiting Earth, and a solar thermal co-generation plant located in the middle of the Pacific Ocean. The Fresnel lenses would operate near their material softening point, and the ocean platform would operate at a temperature ideal for generating steam. This design could generate up to 518 gigawatts of usable, uninterrupted electricity for public use, and 1538 gigawatts of heat for distillation of cellulose ethanol fuel for transportation. For comparison, an equivalent solar powerplant consisting of photovoltaic or solar concentrators in Earth orbit would have to be approximately 49 kilometers in diameter to deliver the same amount of electricity, and would be entirely composed of expensive high-quality mirrors or photovoltaic panels. Each 600-meter diameter optical lens therefore represents a 6705-fold reduction in surface area for a solar power satellite. Since reducing a spacecraft size often reduces its mass and cost, the use of a Fresnel lens to transmit collimated solar energy directly from the Sun’s corona to Earth may prove to be a significant advantage for space-based power generation."
So, this design could be several thousand times less expensive than an equivalent photovoltaic solar power satellite, just because it is so much smaller. Plus the size, though large, is still within reason. So there is a small possibility that it could be built, as opposed to none at all. Further cost estimates are difficult, obviously a great deal of design work still needs to be done. One would have to create a detailed design, right down to the nuts, bolts and paint job, to really estimate the cost. Seriously, I'd love to be paid to design it for real. At the moment it's a hobby.
I think that maybe by assesing the number of tons that need to be moved into space, then use reference numbers for cost of development of other spaceproject (what was the weight and how big was the budget) and combine that with cost of transferring ayload, discoutn for size of project and you are getting there. On the revenue side do likewise. Value of energy etc.
I do however believe that it does not make much sence without at least a very rudementary assesment of project economy - because what else should drive such an effort?
Best regards
Morten
Best regards
Morten
