Reference Points
Reference Points
Reference Points
Aparently you can't use a Referece Point as a perameter to define a new reference plane (via point and parallel plane).
What are reference points for if you can't mate to them and they can't be used to make new geometry?
RE: Reference Points
good point.  if i want to use a point for this i make a point in a 2d or 2d sketch and use it as you describe using the parallel to a plane at a point option.
I'm not sure what you mean by "can't mate to them." I just used a reference point for mating. Specifically, I've got two tubes with beveled ends which need to be mated. One of the mates I use is to create a reference point (in one of the part models) in the center of the beveled face. In the assy, I mate the reference point to the top plane.
Bring back the HP-15
www.hp15c.org
