Freebody display in FEMAP
Hi all
I'm am working on a model i FEMAP and have choosen to show the reactions with the freebody capability. However, I minor glitch is annoying for the moment. I want to show the numbers with less digits and can't find any way to do this.
(Instead of reaction 157.12 I want the display to read 157.)
I have tried the view-options-criteria with no luck.
Any help is appreciated.
Thomas H
Thomas H
RE: Freebody display in FEMAP
Try view options->contur/criteria style-> digits
and set 3 /befor 5/.
Thanks for your input. Unfortunately the method you suggested does not work, I've tested it before. It works fine for contur/criteia plots but not for freebody's. This might also be because I work with FEMAP 8.2. I'll just wait for version 8.3 to what happens there.
Thanks anyway
Thomas
