3D Sketch in hole wizard
Is there a sure-fire way to NOT get a 3D sketch when creating a hole using the hole wizard? This seems to be the first sketch created when placing the hole. The next sketch (the hole's revolved profile) is a normal 2D sketch.
I would prefer a "standard" sketch as it is easier to define. (I say "standard" even though the 3D sketch seems to be the default).
Air cooled, belt fed, gas operated machine gun firing from the open-bolt position
RE: 3D Sketch in hole wizard
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
