Carriage Return
Carriage Return
Carriage Return
     The search function is down right now on the site and I remember reading about a carriage return that could be used to force text to another line.  Can this be used in the file properties.  I have a material description that is pretty long and needs to be.  I want that exact material description showing up on the drawing without using multiple material file properties (i.e. material_1, material_2) and I need the text to wrap or be forced to another line using a carriage return.  Is this possible?
Pete
RE: Carriage Return
Scott,
   I can get the carriage return in my file properties, but the note on the drawing that pulls in this file property info does not want to wrap at the carriage return.  Instead it just shows the carriage return symbol without actually wrapping the info.  Any ideas?  Thanks.
Pete
RE: Carriage Return
Will the Character Map number work?
Ken
RE: Carriage Return
SBaugh,
I don't know about the SW BoM, but with the Excel BoM you can get a Carriage Return within a cell by doing this:  make the cell a concation of multiple cells/text and wherever you'd put an [Alt]+[Enter] in normal Excel type &" and then hit the [Alt]+[Enter] and then do the closing "
So the following (all in one cell):
="Go"&"   <---hit [Alt]+[Enter] after the last "
"&"Buckeyes!"
Will give (in that one cell):
Go
Buckeyes!
Ken
RE: Carriage Return
SBaugh,
I just happened by the original post and it had another method in there to, see below.
Ken
Multi-lines in a BOM (single cell in Excel)
Use:
=A1&""&B1
as the formula but between the "" enter ALT and ENTER keystrokes.
Format the cell to enable wordwrap too...
Another way to make this work.
The 'alt-enter' character is also 'Char(10)' in ASCII.
So this will also work:
=A1&CHAR(10)&B1
Again, format the cell to enable wordwrap too...
RE: Carriage Return
This is all well and good, but doesn't solve my problem.  I assume the SolidWorks annotation just doesn't understand the carriage return.  I don't want to show this information in a BOM, just in a note.  Wonder if the annotation function in 2005 will understand a carriage return?
RE: Carriage Return
Not sure if this will work but this is what I use in a macro
"Note: Remove Relief" + Chr$(13) + Chr$(10) & "Bend Radius"
returns
Note: Remove Relief
Bend Radius
Good Luck
RE: Carriage Return
Here is what you need to do, I did this and it works fine:
Follow the link I provided to you above.
This what I did:
1) Make a new part
2) Add a DT to that part
3) Add a property to the part e.g. - $prp@Description
4) I gave it a value - "This is a test to show a (I used the keyboard to make a Carriage return here, using this Combination of keys - Alt+Enter)Carriage Return"
5) I closed the DT and it made a new config
6) File\Properties\Configuration specific tab
7) There in my list is a description and it has my value plus it has a symbol indicating a Carriage return is there.
8) I started a drawing and added a note
9) I linked it to the Description property and wouldn't you know it. The text was forced down a line. e.g.
Carriage Return
Going back to Rule (7) - Since you now have the symbol for a Carriage return, you can copy that symbol out of the custom property and paste in other custom properties, notes, etc... and it will work fine. You don't have to maintain the DT to keep the Carriage return to work. You can delete it.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
RE: Carriage Return
I use the same system all the time Scott but I think he is using Custom File Properties, not the Custom Properties that normally are added in a DT.  I think they are adding them via Windows File Properties.  (I am probably totally wrong).
RE: Carriage Return
That what I'm saying! If you make a file (I don't care if's a new crap file or not, just make a new one) add a DT to the part. Create a custom property in the DT, use [Alt+Enter] and close the DT. The Carriage return symbols will show up in SW, under File\Properties\Configuration Specific tab. You can copy the actual symbol out and paste to your hearts desire.
If your talking about something other than SW Custom Properties then I don't know what to tell you then. But I can make this work in SW without a problem. Heck I can even send you my example if you want it.
Scott Baugh, CSWP
RE: Carriage Return
I understand what you are saying.  I am not using the configuration specific properties - not that it should matter.  I had been able to copy the carriage return symbol or at least I thought that I did, it showed up in my file properties, but the note was not respecting the carriage return.  I used the DT table method and all seems to be fine.  I since went back, deleted the DT, copied the config specific prop to the custom tab, then deleted the config specific prop.  After a rebuild on the drawing, the note stayed the same - with the carriage return respected.  If SolidWorks can display the carriage return and notes can understand it - then it seems there could be functionality added to the file property dialogue box to insert a carriage return for you, i.e. enhancement request.  It could be a simple button that gets clicked that inserts the carriage return.  The next question is how downstream apps view/respect the carriage return - things like PDM, PLM, integration with ERP/MRP.  I'm not up on the PLM or ERP/MRP integration so I don't know what the carriage return would do there, but I will see how PDM/Works displays the carriage return - probably with the symbol.  Thanks Scott for your help.
Pete
