Greater than or equal to symbol
I'm trying to enter a Greater than or equal to sign using the symbol manager from the Mtext editor, with no success. I've also copied the symbol to Notepad and tried to import the text file, but it translated in as == instead of >=. If I underline the Greater Than symbol, it will work, but the underline then extends to the remainder of the text.
Thanks for any thoughts,
Mutt
Mutt
RE: Greater than or equal to symbol
Steve Smith
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
only sign it should not extend past it. Are you highlighting the > only when you select the underline button? That should get you what you want.
Steve Smith
Product Engineer
www.stacoenergy.com
Try this and see if it works
With Dtext your stop characters worked, but when converting to mtext it went back.
Steve,
Someone else also told me that they were able to selectively underline, but it hasn't worked for me. It extends to everything else in the text window after I click OK. I've recently installed Express tools, I wonder if that has anything to do with it?
I haven't tried setting up a new text style, I'll see where that gets me.
Thanks for the responses!
mtm
My Regards,
Steve Smith
Product Engineer
www.stacoenergy.com
when I tried in mtext, I could select just the symbol and underline it and it was fine, so I'm not really sure what the problem is.
I made a small notepad reference file for future reference containing CDH's first.
%%u>%%u is "greater than and equal to".
%%u<%%u is "less than and equal to".
%%>%% is "greater than".
%%<%% is "less than".
Katy Cook
Engineering Systems Coordinator
F. E. Myers, Co.
