DRAWING ENTITY
DRAWING ENTITY
I AM DOING THE ASSEMBLY DRAWING.
HOW AND WHAT CAN YOU ADD ON THE DRAWING THAT YOU CAN SHOW DUAL DIMENSION (INCH/MM). I SKETCH ENTITIES BUT IT ONLY GIVE SINGLE DIMENSION?
THANKS FOR YOUR HELP
RE: DRAWING ENTITY
If this is a Metric drawing then go to STANDARDS > MODEL and set the scale
to 25.4. Then change the DIMS2 to an Inch dimension. Next -- add the dims.
Sorry I can't help better with the exact steps, but I'm at home --- between jobs.
RE: DRAWING ENTITY
MY PROBLEM IS ADDING ENTITIES ON THE DRAWING MODE WHERE YOU CAN ALSO APPLY DUAL DIMENSION TO THESE ENTITIES.
AND ALSO, HOW CAN YOU SHOW A LINE THAT IS OFFSET TO THE EXISTING EDGE OF THE PART?
RE: DRAWING ENTITY
RE: DRAWING ENTITY
RE: DRAWING ENTITY
I hope this is what you need,
