Automatically viewing new sketch from normal
Is there a setting I'm missing by which I can have the view automatically display normal to the plane of a newly created sketch?
Bring back the HP-15
www.hp15c.org
RE: Automatically viewing new sketch from normal
I guess I have never noticed this before and I know I have never looked for it.  I tried working on a new plane instead of a face of a part (because it works on the planes for the first sketch) but have found that the only time the model automatically normals up is on the first sketch.  Sorry, I am not able to help,I just figured I would share what I found.
aamoroso is correct; the "normal to" function is only automatic on the first sketch.  After that, it's manual.  You could always get around that limitation with the API, though.
Just setup a Hotkey like "Ctrl-N" or just "N" and use that for "Normal To" when in a sketch.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
"CTRL 8" is set up for this Normal to View by default in SW2004 and later.  I change mine to "N" because I use it so much.
