Matlab compiler
Matlab compiler
Matlab compiler
I am having a problem with compiling a m file that uses the load(filename) function(that reads input from a .txt file) into a stand alone program.
it gives an error while excuting the .exe program which says:
Exception ! File: handler.cpp, line 73
             can't open File c:\thru.txt
and it points an error in the line of the .m file which contains the load function.
I am using Matlab 6.5(release 13),visual studio.Net(VC7),and matlab compiler.
So if anybody could help please do so,i will be very greatfull........
RE: Matlab compiler
The Compiler documentation declares that you cannot compile
"M-files that load text files, for example:
load -ascii sampling1"
However, you can use the fopen and fread functions to read the contents of the file. These functions can be compiled.
