Setting Measurment Options Decimal places
Hello all,
Does anyone know how I can use the custom props for mass in a drawing and have it show 1 or 2 place decimal? The problem with setting the assembly or model to 1 or 2 places is that it will effect the measurement in that model. I want to beable to measure to a 4 places in the model but have the drawing show a 1 or 2 place from the properties.
thanks
thanks
RE: Setting Measurment Options Decimal places
"Decimal places" can be set independently from each other when it comes to models and drawings. If you go to: Tools/options and then click on the document setting tabs, there will be a unit’s option. The one in the model is independent from the one for the drawing. When it comes to measuring in the model, the situation is the same for the measuring tool. You can set its decimal places to whatever you want in the measuring tools window option tab.
Hope this helps.
IS there away to change this in the drawing link but not change it in the model?
thanks
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Add that with the number you require and it may work for you.
Jim
Nz
Is what you want to do is have the number of decimal places for mass properties to be 4 in the modle and the assembly but have it display 2 desimal places in the drawing?
