Replacement for threading
What are generally good replacements for threading for adjusting a seat ring on a tube? I need to fix a ring on a tube, and be able to adjust its height.
Any questions, just post below. Any help would be greatly appreciated.
Cheers
Mike
Cheers
Mike
RE: Replacement for threading
You don't want too much play, I would keep the tolerances in the ring between 0.002 and 0.005 inches. That way there is not too much slop in the adjustments.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
http://www.ringfeder.com/ringfeder.htm
http://www.bostongear.com/products/shaft/sclamp.html
In addition to Arto's post, Fenner and others make the taperlock range of locking sleeves.
Jeff
