Spline Import
Spline Import
Spline Import
I scanned in a sketch and traced over it in Illustrator, then I exported to DXF, however solidworks won't import it. The import wizard runs, and gives a preview of the sketch but it throws an error. Sorry, I'm writing this a day later and from a computer that has internet access, but the error says something about splines and has a list like this:
handle: 2c
handle: 3b
and it doesn't do the import.
Any thoughts? Is there a better way to go from Illustrator to solidworks, or maybe somewhere I can get a checklist for the best way to make a drawing in illustrator that will be most compatible?
-Thanks
RE: Spline Import
Why not trace the scan in SolidWorks?  Import your scan to a sketch and make the spline directly--will save a lot of hassle and keep things as native as possible.
Open a new sketch, then, Tools > Sketch Tools > Sketch Picture.  Select your scan (JPEG or whatever), select the size you want it to appear (scaled) and it's part of your sketch.  You can then start a new sketch over the scan and use splines or whatever you like to get perfect data.  Works with photos, too.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
RE: Spline Import
Yeah, that's probably what I think I'll do. Thanks!
RE: Spline Import
This sounds like an OK solution if you need to do a logo one time but there has to be faster way if one frequently needs to work with designers handing over .ai drawings.
RE: Spline Import
I've been able to solve some DXF import issues by deleting the header from the DXF file.  This is done by opening the DXF file in a text editor (Notepad or Wordpad) and deleting the header information there.
"When everyone is thinking alike, no one is thinking very much." --Eckhard Schwarz (1930--2004)
http://www.EsoxRepublic.com
RE: Spline Import
When I had access to several pieces of software, I would read in a DXF from Adobe Illustrator into CADKey, use "Interpret splines as polylines" and then export it back out and into SW.  Then it was just a series of short straight lines.  If SW would work on the import code to read splines, this would be great.  I am sure that Solidworks is becoming more and more commonly used and many engineers have to incorporate data from Adobe Illustrator into their files.
